Crank no start
186,500 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
WROJAS0919
  • 13 POSTS
Cranks but no start, sprayed starter fluid no start. there is spark, but there is no power to fuel pump.
Jun 16, 2020 at 12:49 AM
So when you sprayed starter fluid it did not start but you have spark and no power to the fuel pump? If so, we have a fuel issue but not starting with starter fluid contradicts this. So I am wondering if you did not spray enough for it to fire the engine or you took too long between spraying the fluid and starting the engine.
I just want to double check this because I would hate to chase a fuel issue when we have something else. So this confirmation of it firing one starter fluid just shows everything else is working.
May 21, 2021 at 10:56 AM
WROJAS0919
  • 13 POSTS
Okay, so I had time to work in it and here’s the thing: now there is power to fuel pump, there is power to injector but there is no spark on any cylinder.
Okay. I attached the testing that we need to find out why we have no spark. Let's run through this and see what we find.
WROJAS0919
  • 13 POSTS
Thanks for the instructions. so, yes there is no spark on non of the cylinders and there is a code for coil 1 cool 2 coil 3 and coil 4. also I got a code that says immobilizer not set up.
Okay. What are all the codes that you are getting so we can work through this? Thanks
