crank, no start draining new battery
190,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
PABLO ROBERTSON
Car will try to turn over, but will not. Crankshaft, cam sensors
replaced, new battery, alternator checked, starter checked, fuel pump checked, injectors and coils all check out good. oil was changed and the issues started. ran smooth, good mileage, no other problems.
Jun 17, 2017 at 4:00 AM
  • 55,780 POSTS
When you changed the oil did you use the correct weight? If you use the wrong oil it will hold the lifters up causing the engine to loose compression.
Cheers, Ken
Jun 19, 2017 at 4:54 AM
PABLO ROBERTSON
Ill have to check that. The car ran fine for two days after the oil change.
Jun 19, 2017 at 7:24 AM
  • 55,780 POSTS
Yep that's about how long it takes. Let me know please.
Cheers, Ken
Jun 19, 2017 at 1:58 PM
