crank no start but have spark and looks like fuel too?
1994 CHEVROLET S-10
225 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BUZZ3XXX
94 s-10 died at while going down road. towed home, noticed check engine light on solid, used scanner and no DTCs. However light is on solid. Then looked to see if fuel is coming via TBI, looks like is coming in. changed fuel filter as well. Then checked spark, connect spark plug to coil wire and crank have good spark. then connected spark plug to #1 cyl and see spark and did the same for number 4 cyl and also see spark. since light check engine light is on solid. Today I replced the entire distributor as well, to elminate the pickup and ignition module. still nothing. I am now looking at wiring, the pink wire going to coil has 12v. The white wire I am trying to check but not sure how please advise. OR if you have other thing to check for this please advise thanks
Jan 15, 2026 at 8:27 AM
  • 55,433 POSTS
It sounds like you may have lost compression, can you please follow this video and report back with the readings?
https://www.youtube.com/watch?v=KOxIm1F8AW0
Also, I have seen the catalytic converter fall apart internally and block the outlet which chokes off the engine. I know you see the fuel entering the engine but can you try staring fluid as well to see if you have lack of fuel or it is contaminated, (water)? Please go over this video as well.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&pp=2AYB
Let us know what you find. Please upload a short video in your response of the problem, so I can see what's going on. Ken
Jan 17, 2026 at 2:13 AM
