Crank no start after running out of gas?
10,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
JARED LANKHAAR 1985
Ran car out of gas now it won’t start.
Feb 1, 2023 at 5:54 PM
  • 55,628 POSTS
It is typical for the fuel pump to go out when run dry without fuel to help cool and lubricate the pump. When you turn the key on without starting the engine do you hear the pump run for about 5 seconds in the tank? if not, I would drop the tank and install a new unit here are the instructions for the job in the images below. The fuel tank must be removed first, and you must drain the tank.
This video will help:
https://youtu.be/Q5MH2gnyFH0
Feb 2, 2023 at 3:24 AM
