Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Alero
Engine
Symptoms
Not Running
Crank no start
1999 OLDSMOBILE ALERO
1,235,000 MILES • 0.6L • 6 CYL • 2WD • AUTOMATIC
BIZKUT13
MEMBER
1 POST
Replaced ignition switch, fuel pump, ECM, new brakes, oil change, crank position sensor and new alternator.
Feb 13, 2021 at 7:27 AM
Experienced Mechanic
Was all this replaced to try and fix this issue or did all this happen after you did all this?
https://youtu.be/dCjmRL3p4Cs
Also, we need to check fuel pressure just to make sure it is correct.
If this happened after all these parts were replaced then I suspect you have a faulty crank sensor but let's start with this and go from there.
Thanks
Feb 14, 2021 at 9:27 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
