Crank no start issue?
88,567 MILES • 5.7L • V8 • 2WD • MANUAL
R6VETTE
  • 11 POSTS
I need some help because my C4 will continuously crank but won’t start. This was a project car and I had never got it to run before. I had an issue with the fuel pump not priming on key turn, but I fixed that issue and now have 45lbs of fuel pressure. I’ve replaced the Opti, ICM, and Coil. Could this be an injector issue? Or maybe clogged injector?
I have checked for spark (not blue) at wires and checked for ignition pulse both are there.
Following the FSM Chart A-3. On crank, the tachometer displayed no rpm. Probing terminal C with a test light did show a light, and lastly, checking for continuity of terminal D to ground showed 0.3 ohms, per FSM it’s either the distributor connection or the distributor.
I got the connector on order and wondering if there is anything else I should check before buying another optispark if the connector doesn’t fix the issue?
Apr 18, 2023 at 11:42 AM
STEVE W.
  • 15,418 POSTS
Okay, if you have spark have you checked that it's in time? Next try spraying some fuel into the intake and see if it will at least try to start, that will help to narrow down if it's fuel or spark. If it has been setting a while it could be the injectors have gotten clogged with dried fuel, spraying fuel in may help to determine that. You can also try to power the pump directly and bypass the relay and see if it helps to have constant fuel. Another thing that would show would be if you smell fuel in the exhaust. Then for spark a spark tester plugged into plug 4 as a quick test, if the spark is there but weak, connect the tester in line with the coil and test there. If you have good spark there, then you will want to pull the opti off and clean under the cap as it could be corroded from setting.
This is a pretty good video on testing it in the car:
https://www.youtube.com/watch?v=9szDBiEX3cg
The signals he talks about will be there during cranking as well. You could use an old school analog meter to watch for the square wave or if you wanted a cheap scope would really be a better thing.
Apr 19, 2023 at 6:19 PM
R6VETTE
  • 11 POSTS
After I sprayed the starter fluid, it briefly seemed to start. Here are some videos of checking the spark at the coil and plug 2, along with a picture of a brand-new spark plug. The horizontal video is the Coil. I'll charge up the battery and check with starting fluid again.
Apr 20, 2023 at 1:24 AM
STEVE W.
  • 15,418 POSTS
That spark should be fine. As it seemed to start on spray I would go after the fuel system. You have 45 PSU at the test port so either the injectors are not firing, or they are clogged. I would go to the fuse box with a test light and verify that you have power to both injector 1 and 2 fuses, then go to an injector on each bank and unplug one and see if you have power on the black wire. If you do then take a mechanics stethoscope and use it to listen to the injector, you should be able to hear a defined click as it triggers. If it sounds muffled or nothing at all the injectors need to be cleaned at least. That can be done by removing them and soaking the tips in a carb cleaner. Then test again. Or if you don't want to fight with them, just get a set of matched injectors and install them.
I would also worry about how old the fuel in the tank is, especially if it had ethanol in it. For that you could use a jumper wire to battery positive in the fuel pump fuse to power the pump, disconnect the fuel line at the fuel rail and use the in tank pump to remove the old fuel, dump in 4-5 gallons of new fuel and pump a half gallon of that through, then reconnect it to the rail and put the fuse back in and see if it starts now.
Apr 20, 2023 at 7:18 AM
R6VETTE
  • 11 POSTS
I ordered an injector cleaning tool from Amazon and discovered that only 2 of the 8 had power, indicating that I probably need new injectors. Since I wasn't obtaining fuel pressure before, I cleaned out the varnished fuel in the fuel tank and bought a new fuel pump.
Apr 27, 2023 at 1:08 AM
STEVE W.
  • 15,418 POSTS
If the lack of power was at the connector I would check the harness, corrosion in a connection could stop power out to the injectors.
Apr 27, 2023 at 4:16 AM
R6VETTE
  • 11 POSTS
I tested the injectors out of the car with 12v via a battery using the tool and only 2 would pulse and spray fluid. So, you’re saying to check for voltage on each connector for the injectors on crank/key? I should get new injectors also, correct?
Apr 27, 2023 at 4:28 AM
STEVE W.
  • 15,418 POSTS
Okay, if you tried them out of the car and they failed I would replace them. I would also check the power feed to each one just to be sure that it was the injectors failing and not that there is a problem now from that failure. I have seen shorted injectors cause a driver circuit failure due to the higher current from the shorted parts.
Apr 27, 2023 at 4:51 AM
R6VETTE
  • 11 POSTS
Fuel injectors were the issue got it running. Thanks Steve.
May 4, 2023 at 1:57 AM
STEVE W.
  • 15,418 POSTS
Great to hear, Now get it out there on the road! 'Vettes deserve to be driven.
May 4, 2023 at 6:26 AM
