Crank no start, fuel pump is not turning on?
185,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MRSSCRUGGS3921
  • 12 POSTS
Ignition locked up on me. Car sat for over a year. Finally got around to replacing the ignition switch, lock cylinder, the whole ignition set up is new. Paid locksmith to come out and program the key. Still won't start. Fuel pump isn't coming on. All fuses, relays etc., have been checked. All good. I don't know what the issue is but I'm so fed up I'm ready to either sell it or haul it to the scrapyard. I'd do not want to have to do that because I love the car and when the ignition locked up the car didn't even have a check engine light on. It was in perfect running condition. Please someone help!
Nov 3, 2023 at 12:38 AM
  • 55,694 POSTS
When you turn the key on and try to crank the engine over does the security light flash? If so, this is the problem, I would call the locksmith out again because the programming was not done correctly. Also, let's run the codes to see if any are stored.
Please go over this guide and get back to us.
Nov 3, 2023 at 3:56 AM
MRSSCRUGGS3921
  • 12 POSTS
No, the security light is solid.
Nov 3, 2023 at 4:18 AM
MRSSCRUGGS3921
  • 12 POSTS
No codes.
Nov 3, 2023 at 4:19 AM
  • 55,694 POSTS
Will the engine run on starting fluid? If so, let's check for power at fuse for the fuel pump (f/pump) which is under the hood inside the fuse panel.
This guide can help, Check out the images (below). Please let us know what you find.
Nov 5, 2023 at 3:11 AM
MRSSCRUGGS3921
  • 12 POSTS
No, won't run on starter fluid.
Nov 5, 2023 at 3:34 AM
  • 55,694 POSTS
How does the engine sound when cranking over, can you upload a video so I can hear it? Let's check for spark and compression. here are two guides to help us see what's going on:
and this video will show you how to check for spark:
https://youtu.be/baq_aEWNQ0Y?si=jK-eSDj4J67SXhD1
Please go over these guides and get back to us.
Nov 6, 2023 at 12:09 AM
