Engine cranks over but does not start up and run?
13,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NEW92NEW
Will turn over but acts like it is not getting gas. Codes pop up as p0113 and p2647. New battery and fuel pump works. Hope to fix it soon.
Dec 2, 2018 at 6:57 AM
Good evening,
Did you check for spark at the plugs to verify spark?
Did you check the compression?
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
The 113 code is about the mass air flow sensor.
2647 is about the oil pressure switch and wiring.
P0113
Descriptor
Probable Causes
Engine Control Module (ECM)/Powertrain Control Module (PCM)
Engine Control Module (ECM)/Powertrain Control Module (PCM) Update Needed
Mass Air Flow (MAF) Sensor/Intake Air Temperature (IAT) Sensor
Poor Connections or Loose Terminals At Mass Air Flow (MAF) Sensor/Intake Air Temperature (IAT) Sensor and Engine Control Module (ECM)/Powertrain Control Module (PCM)
Wire Between Engine Control Module (ECM)/Powertrain Control Module (PCM) B32 and Mass Air Flow (MAF) Sensor/Intake Air Temperature (IAT) Sensor Open
Wire Between Engine Control Module (ECM)/Powertrain Control Module (PCM) B34 and Mass Air Flow (MAF) Sensor/Intake Air Temperature (IAT) Sensor Open
2647
P2647
Descriptor
A/T Except Pzev Models
Pzev Models
Probable Causes
Engine Oil Level
Oil Passage Between Engine Oil Pressure Switch and Rocker Arm Oil Control Valve Filter
Poor Connections or Loose Terminals At Rocker Arm Oil Pressure Switch
Poor Connections or Loose Terminals At Rocker Arm Oil Pressure Switch A, Rocker Arm Oil Control Solenoid A, and Powertrain Control Module (PCM)
Poor Connections or Loose Terminals At Rocker Arm Oil Pressure Switch, Rocker Arm Oil Control Solenoid, and Engine Control Module (ECM)/Powertrain Control Module (PCM)
Wire Between Engine Control Module (ECM)/Powertrain Control Module (PCM) C22 and Rocker Arm Oil Pressure Switch Open
Wire Between Powertrain Control Module (PCM) C22 and Rocker Arm Oil Pressure Switch A Shorted
Wire Between Rocker Arm Oil Pressure Switch A and G101 Open
Wire Between Rocker Arm Oil Pressure Switch A and Powertrain Control Module (PCM) C22 Open
Wire Between Rocker Arm Oil Pressure Switch and G101 Open
Dec 2, 2018 at 7:09 AM
