crank no start. but if i pull the plug wire it starts right up. zero volts to the ignition coil pig tail. just weird.
Oct 14, 2024 at 1:33 AM
✓Experienced Mechanic
Which wire do you pull off to get it to start? It sounds like the TIPM is going out. Let's do a CAN scan to see which codes are stored. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
