crank no start, zero volts to the ignition coil?
280,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
EARL91
  • 88 POSTS
crank no start. but if i pull the plug wire it starts right up. zero volts to the ignition coil pig tail. just weird.
Oct 14, 2024 at 1:33 AM
  • 55,711 POSTS
Which wire do you pull off to get it to start? It sounds like the TIPM is going out. Let's do a CAN scan to see which codes are stored. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Have you checked the fuses? Please go over this guide and get back to us.
Oct 14, 2024 at 4:26 AM
