Crank no start
350,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
SIMPERFI84
  • 14 POSTS
I have a new GM factory 5.7l vortec engine installed in my truck, along with a re-manufactured 4l60e transmission. Had everything running great. With approximately 400 miles on engine and transmission. Now I have a crank no start issue. I have confirmed good spark and fuel. I did change the fuel pump after this issue. With a Delphi pump fuel pressure is 62psi, I pulled pelium and confirmed, no leaks in injector assy, getting fuel to all eight injectors. Spark is good. Pulled distributor for visual inspection, dist is new by the way, everything looked okay. Reset engine to TDC on comp stroke reinstalled distributor. Swap rotor and cap with know good, rechecked spark which was good . I tried spraying starter fluid into intake. Still have a no start issue. Timing chain is not broken rotor spins while cranking, any suggestions as to what to check next?
Dec 18, 2019 at 1:10 AM
SIMPERFI84
  • 14 POSTS
I have checked the grounds, I can go back over them to confirm good clean contacts. I did swap out the cam shaft sensor with the one from the original but no joy there. I did check for good 12 v and ground. On the one in the new dist. Wouldn't hurt to get a new one. Thanks for the response. I will update my post when I install the new sensor.
Sep 2, 2020 at 11:00 AM
Good afternoon,
Did you verify power to the spark plugs directly?
Are the injectors firing?
I would also check the compression as well.
The last thing I would do is check for an injector pulse. You can check it with a scan tool or use a noid light to be sure the ECM is commanding the injectors to deliver fuel.
SIMPERFI84
  • 14 POSTS
I did verify spark to all plugs, also replaced spark plug wires, I found a couple boots had cracks in the other set, plugs are new as well. I pulled the plug for the MPFI system check for power, ground and pulse with a test light. I also removed upper peluim and check for leaks while in there found none and visually check each injector for pulse and fuel spray. Confirmed all eight injectors were working. I check cylinders 1 and 2 for compression both at 186psi, I am going to check all eight this weekend. I will post my results. Thanks for the response.
You are welcome.
Always glad to help.
SIMPERFI84
  • 14 POSTS
Good evening Roy,
I did fail to mention the only code I have is a P0102, for MAF, At first I figured it was due to removing the breather, but it won't clear out now. I have unplugged the sensor and tried starting with no joy. I have also noticed that it won't throw a p1345 code even if I turn the distributor a little. Makes me a little suspect of the ECM. Just a thought.
I agree. When you turn the distributor, it should set a code for cam retard.
Sounds like you need an ECM.
SIMPERFI84
  • 14 POSTS
That has been a thought hanging in the back of my brain. How do I go about diagnosing a bad ECM? It does communicate with my scanner?
It can communicate and still not command injectors to fire.
Do you see an RPM reading while cranking?
DAVISMELODY6669
  • 65 POSTS
I have the same problem but my injectors are firing but no spark.new distributor new coil and module.
Okay, do you have any codes set?
Do you have a test light to do some testing?
Year, make, model and engine?
DAVISMELODY6669
  • 65 POSTS
Same truck like SIMPERFI84. I did a upgrade camshaft with all new sensors I have 12v and ground to all connections, but from the coil to a ground or light tester no spark.
Okay, test for power to the positive side of the coil. If you have power, then use the test light on the negative. You should have power there as well. Then have someone crank the motor. With the test light on the negative side. the light should flash with the engine cranking.
DAVISMELODY6669
  • 65 POSTS
On the connection to the coil I have 12v on with the key on hot and the negative side too.
Okay, crank the engine and see if the test light flashes.
DAVISMELODY6669
  • 65 POSTS
Since I put in a new timing cover I do not know if the crankshaft sensor needs a shim.. to make it start.. I also changed the fuses in the fuse box and the wiring harness ain't being grounded. i'm stuck.
DAVISMELODY6669
  • 65 POSTS
So I hook up the clip to a ground and point the tester to the negative side of the connection?
Yes, do the test.
DAVISMELODY6669
  • 65 POSTS
Okay I am going to try it in 2 hours..the light has to stay on while cranking, if there's no light it that a bad ground or something else? The crankshaft sensor could be a part of it to I'm not sure.. because it feels little wiggly like it needs a shim. I do not know if it's a myth about crank sensor being bad cuts off the spark.
Read what I told you. You need a flashing light while cranking.
DAVISMELODY6669
  • 65 POSTS
Okay thanks, your the best. I'am going to try it.
SIMPERFI84
  • 14 POSTS
Roy I do get a RPM reading, If I,m remembering correctly it was around 150 to 175 RPM while cranking.
Keep me updated.
SIMPERFI84
  • 14 POSTS
Will do Roy. I do have a new cam positioning sensor I will install it Friday or Saturday. Getting spark so crank sensor should be good. I also want to pull a fuel sample as well.
Okay. Let me know.
DAVISMELODY6669
  • 65 POSTS
No rpm reading with scanner and no light at all even while cranking..the clip on red battery and tester on negative wire of the coil connection..but I did the reverse and I do have power n lights up on power feed?
Sep 2, 2020 at 11:01 AM
I would suspect a crank sensor on this one.
DAVISMELODY6669
  • 65 POSTS
It was the oil pressure switch that didn't give me spark all these sensors work together... But now engine don't idle and shuts off .the cam swap I didn't degree it..but timing mark is dot to dot..worst of all white smoke came out of the intake?
Oil pressure sensor has no effect on it. That tells me you have a harness issue.
Did you check the cam retard degrees?
DAVISMELODY6669
  • 65 POSTS
I don't know how to check that..is it with the cam card or degree wheel?
No, the distributor is a cam sensor. The cam and crank sensor need to be in sync. There is a spec that needs to be adjusted.
You can check it with a scan tool. That is the only way it can be checked.
DAVISMELODY6669
  • 65 POSTS
Okay I'm going to get my hands on one soon. but white smoke coming out of intake filter is not good right? truck been sitting a year.
Correct.
Did you change the fuel and the pump as well? After a year, the fuel is no good as well s the pump sitting in it.
DAVISMELODY6669
  • 65 POSTS
No I haven't, but I do have pressure even while cranking. I did buy a idle control valve but haven't installed it yet...
DAVISMELODY6669
  • 65 POSTS
Thanks either way for the help, this website is the best help anyone can get,
You are welcome.
Keep us updated.
SIMPERFI84
  • 14 POSTS
Hey Roy, finally found time to work on truck, I checked compression on all 8 cylinders and this is what I got. Cylinders, 2, 4,6,5, read 210psi, cylinders. 1,3,7,and 8 read 205 psi. I also checked spark at all eight plugs I have good spark at all eight. I did discover cylinder #3 seem to me like it was firing continuously, ( no gap in spark) . I hooked a timing light to the #3 wire and it was almost a steady light little to no strobe. Hope I explained that well enough for you to understand me. I am guessing a bad distributor cap. What do you think. I have not replaced cam sensor yet either, ran out of day light today. Let me know your thoughts please. Thanks.
Okay, if you spray starter fluid in the air filter, will it start and stall?
SIMPERFI84
  • 14 POSTS
No it will not. I do know it is getting fuel I have pulled upper peluim and visually confirmed injector pulse and had helper crank engine to see if each injector was spraying fuel.
SIMPERFI84
  • 14 POSTS
Hello Roy, Just wanted to update you on my truck issue. As I mention #3 plug was continuously firing. Done a little research and came across a post with similar symptoms. They said they unplugged the # 3 wire and truck started right up. So I gave that a try today, sure enough it fired right up. Turns out it was the distributor cap. Which I had swapped but after I pulled the distributor to check it for damage. Long story short, I installed it 180 degrees out which still had the same issue. Anyway I swapped caps again just to check putting bad one back on and I also reset distributor. Anyway I got it sorted out and truck is running fine, I will have to scan it for correct cam retard but it has to be pretty close, running good and no codes. Thanks for your help.
You are welcome.
always glad to help.
