Crank no start
115 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
CURTSAAB
Everything is new; crank sensor, fuel pump, fuel filter, injectors, check valve, spark plugs and di cassette. I also have a few di cassette laying around new o2 sensor tried different ECU, no start just cranking.
Oct 21, 2020 at 2:18 AM
We need to check for fuel, spark, and compression as the engine needs these three things to start. So we need to find out which one of these items we don't have. Here are some guides that will help with this in general:
https://youtu.be/dCjmRL3p4Cs
To check for spark, remove the plug and hold it against the block and crank the engine to see if there is spark at the plugs.
Next if you have spark, use starter fluid in the intake and see if it starts for a second or two. If it doesn't then we need to check compression.
Let's start with this info and let me know what you find. Thanks
Oct 21, 2020 at 8:50 AM
CURTSAAB
Okay thanks. will do so.
Oct 21, 2020 at 9:14 AM
Sounds great. Keep us updated on what happens. Thanks
Oct 21, 2020 at 1:08 PM
