Crank no start?
145,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
RANDY PHELPS
Hi, I have replaced crank and cam shaft positioning sensor and have fuel. What else could cause it to run then shut off and not be able to start again for a couple of days then same problem.
Aug 23, 2022 at 11:56 AM
  • 110,248 POSTS
Randy, when it doesn't start, I need you to try something. See if it starts using starting fluid. If it does and then stalls, we know its fuel related. If there is no change, I need you to check for spark to the plugs.
Here is a link that you may find helpful:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Do this so we know which direction to focus. I'm just trying to narrow things down.
Take care and let me know what you find.
Aug 23, 2022 at 2:12 PM
