Crank no start
345,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BRANDONELI
Okay, I plugged a computer to the truck and it tells me the crank sensor. So I buy a new one . Put it on an I be darn, same thing. What else do I need to do? change the camshaft sensor too? Someone help me out. This just happen out the blue nothing else is wrong with the truck. Help
Nov 11, 2020 at 2:49 AM
Let's start with what the actual code is that you are getting. Unfortunately there is normally a few things that can cause these types of codes so let us know what the actual code is and we can figure out next steps.
Thanks
Nov 11, 2020 at 3:23 AM
Good afternoon,
What is the code number that was sent? Codes rarely identify bad parts just failed systems.
When you crank the truck, does the tachometer move up a little showing RPM? That will tell me if the crank sensor is sending a signal to the ECM.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Can you hear the fuel pump run?
I attached the wiring diagram of the system for you.
Nov 11, 2020 at 3:30 AM
BRANDONELI
No RPM movement. The scanner has a screen. So it said crank sensor. Fuel pump comes on. But no start. Should I replace both cam sensor and crank sensor?
Nov 11, 2020 at 3:38 AM
Again, what is the code?
Can you check for voltage to the crank sensor?
Nov 11, 2020 at 3:45 AM
