How do I get the distributor out of the van? From the front, the back, what? Looks impossible to install the advanced auto distributor, Carquest T2700, seems way too long for clearance.
I am a paralyzed veteran, vehicle is a VMI RICON Gateway lift, swivel seat. problem was intermittant no crank, no start. Changing PCM relay fixed it for a day.
FOXTELL 300i shows no rpm when I crank it, no codes but does communicate. No voltage at top pin of ICM, spoutT connector buried and not removed.
Dozens of videos used to trouble shoot. I"think" it is in distributor.
Oct 7, 2017 at 6:11 AM
