After head gasket replacement will crank but not start
2000 HONDA PASSPORT
170,000 MILES • 3.2L • 6 CYL
PAUL6161
I have spark also have fuel press also have 12 volt reference at fuel injector hooked up noid light didn't blink. Pulled crank sensor and I am getting 4.9 volts across 2 pins it is 3 pin connector.
Apr 28, 2021 at 4:49 AM
If you have spark then the crank sensor is ok. Is the theft light on or flashing?
We need to start with checking for codes and see what is there.
Here are a couple other guides that will help with this:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Clearly you have already tested the injectors and are not getting the command to fire them. This is the PCM is not grounding the circuit to open the solenoid. So this is either a PCM issue or another system that is telling the PCM that it is not okay to fire the injector.
So hopefully we have some codes or the theft light is on and we can go from there. Thanks
Apr 30, 2021 at 2:26 AM
