Vehicle ran all day, parked overnight crank no start?
280,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
KEIHINCARB
  • 10 POSTS
Vehicle ran all day, parked overnight, Morning crank, no start. Vehicle RPMs are very low and it idles very slowly and then the engine stalls...
Spark: All 4 spark plugs produce spark, wire resistance measured Ok, External coil resistance measured ok per spec. Distributor (CKP, TDC, cylinder, resistance measured a little lower than spec, no red death bearing wobble.
Fuel: pressure within spec. pump okay, filter, okay fuel pressure regulator okay, injectors pulsing okay.
Timing: (TDC)..Aligned (distributor rotor point to 1, flywheel
mark at + pointer, overhead camshaft marking up arrow and
across cam surface..(no teeth jumping)
Compression: all 4 cylinder at 190-200 PSI...good
Air: filter intake housing ,,,clear....
Throttle body, IACV ,EGR...,cleaned
Sprayed carburetor cleaner into throttle body and
engine runs just fine until fuel source runs out...
Removed fuel rail and tie wrapped injectors Ignition on
/ cranked engine and observed sprayed petrol from each
injector...
Please help...Check next? thanks
Nov 16, 2022 at 10:57 AM
  • 55,746 POSTS
So, you have compression, spark and fuel and it does not run except on starting fluid? This only leaves the fuel that is in the tank is bad. The injectors have pulse and spray fuel, correct?
If this is all true, here is a video to help you drain the tank and install fresh fuel:
https://youtu.be/Q5MH2gnyFH0
Let us know what happens and please upload pictures or videos of the problem.
Nov 17, 2022 at 3:29 AM
KEIHINCARB
  • 10 POSTS
Yes, the engine runs great (as normal) with carburetor fluid as fuel source.
Yes, Injector's all 4-spray fuel. (See photos).
Tank capacity 17 gallons: added 13.88 gallons a few months ago...Driven 325 miles until crank no start. Gasoline in tank more than 1/4 left. Bad Gasoline? Really!! Will drain and replace. Thanks
Nov 17, 2022 at 9:32 AM
  • 55,746 POSTS
If it runs on starting fluid, and the injectors are spraying there is nothing left it can be.
Nov 18, 2022 at 5:30 AM
KEIHINCARB
  • 10 POSTS
Evening,...Update:
Opened tank / bolt-drained 6 gallons..Refilled with 2 gallons 87 octane and 1
gallon 89 octane..After starting/ cranking to get rid of existing "bad" fuel-in lines,
engine ran for a second (to 2000 rpm's) then stalls/ dies..Repeat same, then
each start / progressively worst..Took out spark plugs (fouled / black), one spark
plug resistance is (4.4K ohms), the rest at 3.2K ohms. Will go back to carburetor
fluid test / run-idle and fuel injection test / spray etc..to be sure.....Check fuel off list...
Suggestions???? thanks...
Nov 20, 2022 at 10:15 AM
  • 55,746 POSTS
You could have a clogged exhaust system or catalytic converter. I would install new spark plugs and disconnect the head pipe from the cat to see if you have the engine power back.
Here is a guide to help:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please go over this guide and report back.
Nov 21, 2022 at 2:25 AM
KEIHINCARB
  • 10 POSTS
So that's what it sounds like without a cat / exhaust system...Couldn't hear engine turn over, but noticed the rpm gauge / needle move. Same condition. Not a clogged cat / exhaust system. Any other suggestions? If not, going back to the beginning and start to install (tune-up) items (plugs / wires etc.. (OEM part ie denso / Nkg etc.) Happy
Thanksgiving. thanks.
Nov 22, 2022 at 12:54 PM
  • 55,746 POSTS
Can you remove the oil fill cap to see if the camshaft is turning when you crank the engine over? You may have a bad timing belt.
Happy Thanksgiving to you as well :)
Nov 23, 2022 at 4:23 AM
KEIHINCARB
  • 10 POSTS
Each day after I try to solve this crank / no start condition I typically set the engine to TDC..Distributor pointing to #1 (cap), manual transmission flywheel pointer to white + mark, physically moving / rotating the crankshaft bolt (3/4") CCW.. Decided to remove the spark plugs and measure the depth of the piston in each cylinder from top of valve cover..#1 and #4 at 11", #2 and #3 at 7". Last I looked timing belt was fine (month ago) when I removed valve cover to check camshaft (up arrow ) and marks on camshaft against surface/head for proper timing.. Still puzzled, sometimes engine rpm is normal going to 2000 rpm's (cold start) then one would hope it idles, but dies, and other times crank starts rpm's are so low, engine chugs then dies...Inconsistent...Still hoping to find the problem with your help..Ask me to check on something, more than likely I've already done it...But ask away..I've done a lot of individual testing of components with (dvm, resistance tests and voltage tests /main relay/ignition switch/ tp /distributor ckp/tdc/cyl/external coil/ new fuel filter/ tested /replaced fuel pump(denso w/airtex) / cleaned throttle body/ IACV/ EGR / etc..etc..)..I'm going to see if it'll still run on Carb cleaner (5-10 seconds/ again) and I'll remove the fuel rail w/injectors to see if I still get spray (against paper/again.) Suggestions welcome ...thanks
Nov 23, 2022 at 5:57 AM
  • 55,746 POSTS
Spark, fuel, compression. It has to be one of these. Please recheck them and get back to me.
Nov 25, 2022 at 1:27 AM
