Cranks won't start. OBD 2 does not link with a code scanner. It's diesel. Has been an intermittent problem, but now its permanent.
Dec 13, 2022 at 3:35 PM
✓Experienced Mechanic
It sounds like the PCM has gone out. To be sure let's check the fuses for the car and the OBD2 connector. Here is a guide to help and the location of the connector fuse. There are 2 fuses that run the system, 5 and 12 in the fuse panel behind the left side of the dash.
