The van has been sitting and not run for about six years. I tried to start it and it will crank, but not start. Sometimes it acts like it going to start but will not. It will start with starting fluid, so I am assuming it is a fuel issue. Does this van have a FPDM unit on it for the fuel pump and if so where is it located. I have tested a lot of things including all fuses and relays. Everything seems to be okay. I hate to drop the tank to check voltage at the pump but I am trying to see if it could be something else. I would appreciate any help or advice you have. Thanks in advance Steve.
Sep 22, 2017 at 4:23 PM
