Crank, no start
197,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
SLEWIS4645
  • 5 POSTS
The van has been sitting and not run for about six years. I tried to start it and it will crank, but not start. Sometimes it acts like it going to start but will not. It will start with starting fluid, so I am assuming it is a fuel issue. Does this van have a FPDM unit on it for the fuel pump and if so where is it located. I have tested a lot of things including all fuses and relays. Everything seems to be okay. I hate to drop the tank to check voltage at the pump but I am trying to see if it could be something else. I would appreciate any help or advice you have. Thanks in advance Steve.
Sep 22, 2017 at 4:23 PM
STEVE W.
  • 15,415 POSTS
Okay, you checked all the fuses and relays. It only uses fuse 17 and the fuel pump relay for power to the pumps no pump control module. Easy way to check if the pump is running is to pull the pump fuse and connect an ammeter inline. A pump that is getting voltage and is working will show as a draw of 7-10 amps usually. No current draw = no pump continuity. Much easier than dropping the tank.
You can also pull the relay and probe the pump feed wire with an ohm meter and with one probe to ground and the other on the feed to the pump you should see around 9-16 ohms resistance.
Or just hook a pressure gauge up to the port, you should see 30-45 PSI key on engine off.
What does it have in it for fuel?
The six year old varnish or did you siphon it and put in fresh?
Sep 22, 2017 at 5:09 PM
SLEWIS4645
  • 5 POSTS
Thanks so much for the information. I will try what you say for sure. Actually, the van had very little gas, so I added fresh gas, Fuel treatment, a little Sea Foam. I did go to change the fuel filter but after unhooking the pressure side there was no gas in the line, and really could not smell much. With the fuel line off I cranked the engine and had no gas at all. What does this tell you? Again thanks so much Steve.
Sep 22, 2017 at 5:19 PM
STEVE W.
  • 15,415 POSTS
No fuel with an open line sounds like the pump is either locked up from setting or the line is plugged.
Sep 22, 2017 at 7:02 PM
SLEWIS4645
  • 5 POSTS
Yes, I think your right. I might as well be ready to drop that tank at some point. Can I loosen the fuel line and blow compressed air through the line? If you think of anything else, please send me an email. Thanks so very much for your help Steve.
Sep 22, 2017 at 7:40 PM
STEVE W.
  • 15,415 POSTS
You might be able to blow them out, it depends on how bad they are. It could just be a bad pump.
Sep 23, 2017 at 4:28 AM
