crank no start
120,000 MILES • 3.8L • 2WD • AUTOMATIC
AARON DIXON
i have spark, fuel pump is working. I changed MAS airflow sensor still no start.
Jan 12, 2022 at 6:59 AM
SQM
  • 6,383 POSTS
Have you checked to see what the fuel pressure is?
It is possible to have a weak pump of a faulty regulator which won't allow fuel to enter the cylinder.
On this vehicle with the key on and engine off it should have 53-59 PSI of fuel pressure.
Also, what symptoms did you have before this crank/no start issue?
Please let me know a bit more details.
Jan 12, 2022 at 9:56 AM
