Crank no start
300,000 MILES • 5.4L • 4WD • AUTOMATIC
TNYLEDFORD
Driving home from my girl's softball game my truck started to misfire real bad. almost immediately check engine light came on and i was close to Autozone so i had them put it on the computer to save me time. Said misfire on number three bad coil pack. Well it has been my experience it is not always bad. so i lifted hood and sure enough someone had used the wrong screws at one point and it had shimmied out and coil pack was as far out as could go. I did not have any money on me and home was only about thirty away so i pushed it back down and drove home. ran like a champ until right before my house when it loosened again. got home grabbed a few different screws and got under hood found one to fit right tightened it down. Went to work next morning it ran so bad. Misfire jerking. I thought maybe i ruined plug so decided to change it. Could not get socket to go down for nothing. Took a little mirror seen i dropped screw in there and it was wedged good. Drove to Walmart (single mom from another state no other car) to get some long needle nose. Parked truck. although missing like crazy it ran fine. Got back in to come home to fix it and it started. idled real rough for about fifteen seconds turned off. started again, three seconds shut off, third time it has done nothing but crank sense. I got the screw out, bought new battery. speedometer and rpm's stay pegged 100% of the time even when battery disconnected.
Aug 21, 2017 at 2:15 AM
  • 55,746 POSTS
It sounds like you have two problems. the first is the engine misfire which can be the spark plugs which is must common. When you remove the plugs looks for one or two plugs that have different coloring than the others indicating a injector or low compression problem.
Here are a couple of guides to help you get going:
and
and
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
The speedometer problem sounds like the gauge itself has gone bad. When there is no electrical power going to the car it should be at 0 no matter what.
Cheers, Ken
Aug 22, 2017 at 4:30 AM
