Crank no start there aren't any OBD2 codes?
175,000 MILES • 5.7L • 4WD • AUTOMATIC
PETER HARVEY
I had a bad distributor cap on the vehicle that I replaced along with the rotor the camshaft sensor the crankshaft sensor the coil the ignition control module and the distributor. After doing all this I was getting a bad draw on the voltage as soon as the key went to the ignition position. I narrowed that down to the eng1 fuse circuit. When I remove that fuse the draw goes away. Now a pink wire that is always hot powers that fuse that fuse powers several different devices including all the ones that I replaced and the O2 sensors. I've made sure that the distributor was dropped in correctly that the timing marks line up perfectly. I'm not getting any activity out of the tachometer now when I turn the motor over. I read in the mechanics manual that if there is a short to ground somewhere on the body or whatever, that the PCM will not allow the crankshaft sensor to forward the timing signal to the ICM as well as not allow the injectors to do their job and move the fuel into firing chamber. I confirmed this as there is no fuel being distributed into the firing Chambers the spark plugs remain dry and the tachometer is no longer moving when I am turning it over. I replaced the wiring for the camshaft sensor the crankshaft sensor the coil and the ICM as well as the mass flow air sensor. So there's new wires going to and from the devices to the PCM and from the PCM back to the devices etc. all the ground seem to be in order under the hood. Is it possible that there is another ground that was already an issue that got moved in this whole process to where it's grounding out the system? Perhaps behind the gauge cluster or back somewhere by all the wiring with the trailer brake and harness cluster? There aren't any OBD2 codes. Been messing with this issue for nearly a month and busted my brain trying to figure it out. Has anybody experienced a similar problem like this and maybe have some insight on what to do look for that I've missed?
Nov 27, 2026 at 12:17 PM
