Crank no start
225,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
PFANNENSTIEL47
  • 6 POSTS
Have a crank no start; replaced throttle body, crank shaft position sensor and cam shaft position sensor but to no avail. It just cranks until I get a back fire through throttle body. Have fuel and have spark.
Dec 16, 2018 at 11:51 PM
Good morning,
The first thing I would do is to check the compression to see if the chains have moved.
Backfiring is usually an indication of a timing issue.
https://www.2carpros.com/articles/engine-backfires-while-running
Were there any codes that lead you to replace all those parts?
Dec 17, 2018 at 12:46 AM
PFANNENSTIEL47
  • 6 POSTS
Yea, had a throttle body light pop up and i know Chrysler has an issue with the sensors so it was just a shot in the dark.
Dec 17, 2018 at 5:58 AM
Got it.
I would start with the compression check to be sure it is not a timing issue.
Dec 17, 2018 at 12:14 PM
PFANNENSTIEL47
  • 6 POSTS
So timing is good. reset the timing tried to fire it up and almost started but it is still flooding out and backfiring. it will not bring any codes except p0700 which is a transmission sensor.
Dec 20, 2018 at 1:57 PM
Okay, did you do a compression test to see if there is enough to let the engine run?
Dec 20, 2018 at 2:10 PM
PFANNENSTIEL47
  • 6 POSTS
So no compression on cylinders 1, 3, 5, 7, 6,8.
120 lbs of compression on cylinders 2, 4.
Dec 21, 2018 at 7:49 AM
Okay.
you have internal engine damage. the heads will have to come off.
most likely has valve damage from the timing being off.
Dec 21, 2018 at 7:53 AM
PFANNENSTIEL47
  • 6 POSTS
Thank you sir, that will be another days project.
Dec 21, 2018 at 7:59 AM
yep.
you are welcome.
Always glad to help.
Dec 21, 2018 at 8:06 AM
