I have a strong crank no start?
187,000 MILES • 5.9L • V8
CTROBAUGH
It was intermittent no start now nothing. Once when it did this, I tapped the PCM, and it fired right up. I'm about to replace the PCM but I want to make sure this is my problem.
Feb 13, 2025 at 12:39 AM
CARDOCTOR74
  • 62 POSTS
Welcome,
Yes, that PCM is the issue just remove the connectors and check the pins first if they check out ok then the PCM has water intrusion and will need to be replaced. Very common on these trucks. This is where to start.
I'm very glad to help.
If you found this helpful, I would not object to a tip at the Venmo link below lol. I’m here if you need me.
https://venmo.com/u/hondaguygold
Feb 13, 2025 at 3:00 AM
