Crank no start? just got a brand new battery?
144,488 MILES • 3.6L • 6 CYL • 4WD
EISHIAKELLEY19
Got my car in match driver it to Texas like 3 times and back to Louisiana. I got an oil change the next week after I got it in March, no last month or this month. It was saying I needed an oil change before my time. so, I went to AutoZone and they put 5w-20 instead of 5w-30 idk why! My car started running hot I changed my thermostat, coolant sensor and camshafter bank 2 (oil presser is the only one that’s not on! ) One minute I get it’s my motor! The next I’m getting it’s my starter ! Everything comes on I had just got a brand new battery when I bought the car ! (If it was the starter it wouldn’t do nothing right !? (I have the car listed above SE model)
May 29, 2023 at 11:34 PM
  • 55,456 POSTS
So, sometimes the engine will not crank and other times it will not start and run?
This guide can help but we should run the codes as well:
You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Here is one for about $99.00 if you need it:
https://amzn.to/3ZixY4v
Please go over these guides and get back to us.
May 30, 2023 at 11:09 AM
