Crank no start "sounds dry"
200,000 MILES • 4.3L • 6 CYL • 2WD
E&J
Won't start changed cap,rotor, cam,and crank,sensors. it has orange spark when it first shut off a month ago. it smelled like old gas when I would try to start it. also a little rotten egg smell.like a month before it shut off the fuel gauge stopped working and my husband tried to change heater core. when he put a little gas into the throttle body there is no difference in how it sounds.
Jun 18, 2019 at 1:02 PM
Good morning,
You need to test the actual fuel pressure to see if the pump is working.
Also, I would do a compression test to be sure the engine can produce power.
Where did you test for spark? At the spark plug?
Jun 18, 2019 at 8:48 PM
