Will not even start with starter fluid?
160,000 MILES • 4.4L • V8 • 2WD • AUTOMATIC
SMOKUSPOKUS
Won't start fuel injectors aren't working we had to hot wire fuel pump but still won't even start with starter fluid attempts to start when we choke the intake by hand but still doesn't.
Feb 2, 2024 at 3:12 AM
  • 110,248 POSTS
If the starting fluid doesn't change how it reacts, I need you to check to see if there is spark at the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Feb 2, 2024 at 1:44 PM
