straight 6 crank no start after changing oil pump gasket?
100,000 MILES • 4.0L • 6 CYL • AUTOMATIC
ARIANADANIELLE5345
  • 402 POSTS
2002 laredo 4.0 straight 6 crank no start after changing oil pump gasket, rear main seal, pan gasket, cam sensor, crank sensor, and syncing timing correctly. It started one time but I let go and it shut off. Fathered fuel pressure in lines cuz Schrader valve spews out fuel when pressed.
Oct 18, 2025 at 7:59 AM
STEVE W.
  • 15,419 POSTS
What was the reason for changing the sensors? Did you use OE parts or aftermarket?
Oct 31, 2025 at 5:34 AM
