Crank no start
166,950 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
ILYA ZIKNER
Checked replaced cap and rotor, there is spark! When turning ignition on there is no sound from fuel pump. So I decided to spray carburetor fluid into throttle body and it should start, but it does not.
Jul 9, 2018 at 7:36 AM
Good afternoon.
Did you check the spark at the plugs?
Did you check the actual fuel pressure?
Jul 9, 2018 at 7:53 AM
ILYA ZIKNER
Yes, it does have spark at the wire and fuel pressure at 60psi. It should start when I spray into throttle body! Could it be crankshaft sensor? All sensors good and fuses.
Jul 9, 2018 at 8:13 AM
No, if it was the crank sensor, it would not have spark.
Check your compression.
Jul 9, 2018 at 8:18 AM
