crank no start
260,000 MILES • 4.0L • V6 • 2WD • AUTOMATIC
GUAYUVIN40
  • 7 POSTS
it has fuel pressure, compression, and timing is new and is correct, but it has intermittent spark, one every four or five revolutions new crankshaft sensor , cams sensors work fine hook up a computer on a auto mechanic shop, they said is a internal mechanic problem. I am running out options.
Sep 11, 2016 at 1:07 PM
HMAC300
  • 48,601 POSTS
try resetting security system if no owners manual look online.
Sep 11, 2016 at 11:37 PM
GUAYUVIN40
  • 7 POSTS
Thank you for your input. The security light goes away when key is turned to on position. And the intermittent pulse is on the coils and the injectors.
Sep 12, 2016 at 4:29 PM
HMAC300
  • 48,601 POSTS
check fuses and relay under hood and car pgm or any to do with ECM. try security reset anyhow it may work
Sep 12, 2016 at 11:52 PM
GUAYUVIN40
  • 7 POSTS
Thank you for the tip, but I tried all of that and more. I just find out the injectors also have intermittent signal. It may be the IEPM ? Fuse box. I just want to make sure before I spend the money.
Sep 13, 2016 at 9:22 PM
HMAC300
  • 48,601 POSTS
try wiggling crank sensor connection it may be that if it starts you know it is.
Sep 13, 2016 at 11:38 PM
GUAYUVIN40
  • 7 POSTS
I did, no difference. Thank you
Sep 14, 2016 at 2:01 PM
  • 55,743 POSTS
Is there any trouble codes? It could be the crankshaft sensor going out they had problems with that car.
Please let us know what you find so it will help others.
Best, Ken
Sep 14, 2016 at 2:05 PM
GUAYUVIN40
  • 7 POSTS
No trouble codes only when they get unplugged it will show the code of the sensor unplugged.
Sep 14, 2016 at 2:38 PM
HMAC300
  • 48,601 POSTS
if the shop says it's an internal problem then ask what they meant or it may be a ring on crank is loose or something that is a fluke.
Sep 14, 2016 at 10:39 PM
GUAYUVIN40
  • 7 POSTS
The shop said mechanical the only 2 thing is timing and flywheel, I check it aND it has all teeths aND is straight. I took the front cover off I reinstall all 3 chains and triple checked and the same result.
Sep 15, 2016 at 8:25 AM
HMAC300
  • 48,601 POSTS
may be the cam advance mechanism is bad causing it.
Sep 15, 2016 at 8:45 AM
GUAYUVIN40
  • 7 POSTS
May be.
I will check in to it ,
Thanks
Sep 15, 2016 at 2:17 PM
  • 55,743 POSTS
Hey,
Did you ever get the problem fixed?
Best, Ken
Dec 21, 2016 at 5:43 AM
