No spark or power to fuel pump and some fuses on outer fuse box have no power.
Nov 20, 2020 at 8:36 PM
✓Experienced Mechanic
Good morning,
Can you tell me the fuse numbers so I can get a diagram of the fuse box?
I attached the picture of the fuse blocks for you. Please identify which fuses have no power.
Images (Click to enlarge)
Nov 20, 2020 at 10:08 PM
KRISB1985
MEMBER
That some of my problem too. I don't have fuse cover and having hard time trying find one on line it's Dodge Stratus r/t 3.0 Mitsubishi motor the outer fuse box looks like this. I don't know if that helps any.
Image (Click to enlarge)
Nov 20, 2020 at 10:56 PM
That is the first diagram I posted to your question. Please identify the fuses with no power for me.
I also attached the wiring diagram of the starting system for you as well so we can test the system and find the failure.
