Crank no start
135,000 MILES • V8 • 2WD • AUTOMATIC
STINKNLINCOLN
Turns over won't start. Replaced fuel pump relay. Did not help. This has been on ongoing problem for one and half years. Been to three repair shops when it was running but doesn't show on diagnostic machine. Has started twice with starter fluid. Sometimes it will start fine for months. During a rainy month of downpours it started every time. One thing seems to be when it is parked with the front down on an incline. Another I let it idle for fifteen minutes then drove it one mile turned it off next day wouldn't start. I normally keep fuel tank half to full. I have a new interstate battery that works well.
Jun 12, 2019 at 4:50 AM
Good afternoon,
Did you check the fuel pressure when it does not start? The fact it runs with starter fluid tells me that you have spark.
Jun 12, 2019 at 7:18 AM
STINKNLINCOLN
Yes, checked fuel pressure. No problem there.
Jun 19, 2019 at 4:53 PM
What is the exact pressure?
Jun 19, 2019 at 6:46 PM
