Replaced the crank, cam, and oil sensor and now my jeep will crank but not run..suggestions?
Apr 17, 2022 at 12:06 AM
STEVE W.
✓Experienced Mechanic
What was the reason for changing the sensors and was it running okay on the originals? Did you use OEM parts or aftermarket for the crank sensor, Chrysler engine control systems generally don't like aftermarket crank sensors. Last, if you still have the old crank sensor, put it pack in to see if it runs on it.
