Crank locked up
150,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CKALLEN
  • 6 POSTS
I change the timing chain gasket and now the crank will only move one stroke forward and back and then locks up. Once it hits TDC on piston one the crank will not move anymore. If you reverse it then it stops at the bottom of the stroke. The cam moves perfectly.
Sep 15, 2018 at 2:36 AM
Good morning.
Was this an issue prior to this repair?
Did you touch the timing chain or any parts of the assembly?
Is it possible you dropped something into the intake that went into a cylinder?
Sep 15, 2018 at 2:48 AM
CKALLEN
  • 6 POSTS
No, this was not an issue before.
Once I finished the gasket I went to start it and it tried to start and it locked up. Found out it was out of time. We are timed it and the crank is still locked up.
We have a scope and checked the the cylinders they are clean.
Sep 15, 2018 at 2:54 AM
Okay, if you have a scope, then did you check to see if it has a valve that is bent?
Sep 15, 2018 at 3:01 AM
CKALLEN
  • 6 POSTS
All the valves seated properly. Maybe I bent a piston rod. But the only I want really sure about is if the transmission could lock it up or the crank positioning sensor could being doing so vudo.
Sep 15, 2018 at 3:09 AM
No to the transmission and no to the crank sensor.
For a rod to bend, something happened to cause this. If all you did was a gasket, it does not make any sense. The fact your timing was off is even more puzzling since you did not touch the chain.
Sep 15, 2018 at 3:16 AM
CKALLEN
  • 6 POSTS
Well the harmonic balancer is not spline or keyed. It has that friction washer to move the timing gear. So when I took it off I did not mark it because it was at TDC and I thought it would have something keeping it on. When I put the balancer back on it was not lined up properly.
Sep 15, 2018 at 3:20 AM
Can you post a picture of what you are talking about?
Sep 15, 2018 at 3:46 AM
Timing Alignment:
NOTICE: Do not loosen or remove the crankshaft pulley bolt without first installing the special tools as instructed in a procedure. The crankshaft pulley and the crankshaft timing sprocket are not keyed to the crankshaft. The crankshaft, the crankshaft sprocket and the pulley are fitted together by friction, using diamond washers between the flange faces on each part. For that reason, the crankshaft sprocket is also unfastened if the pulley bolt is loosened. Before any repair requiring loosening or removal of the crankshaft pulley bolt, the crankshaft and camshafts must be locked in place by the special service tools, otherwise severe engine damage can occur.
NOTICE: During engine repair procedures, cleanliness is extremely important. Any foreign material, including any material created while cleaning gasket surfaces, that enters the oil passages, coolant passages or the oil pan can cause engine failure.
NOTE: Assembly of the engine requires various inspections/measurements of the engine components (engine block, crankshaft, connecting rods, pistons and piston rings). These inspections/measurements will aid in determining if the engine components will require replacement. For additional information, refer to Engine System - General Information See: Engine > Procedures.
NOTICE: Failure to position the No. 1 piston at Top Dead Center (TDC) can result in damage to the engine. Turn the engine in the normal direction of rotation only.
NOTE: The Crankshaft TDC Timing Peg will contact the crankshaft and prevent it from turning past TDC. However, the crankshaft can still be rotated in the counterclockwise direction. The crankshaft must remain at the TDC position until the timing drive components and crankshaft pulley are installed.
Install the Crankshaft TDC Timing Peg and rotate the crankshaft slowly clockwise until the crankshaft balance weight is up against the Crankshaft TDC Timing Peg. The engine is now at Top Dead Center (TDC).
NOTE: Due to the precision interior construction of the balancer unit, it should not be disassembled.
NOTE: The original adjustment shims must be installed in their original positions.
NOTE: Confirm by visual inspection that there is no damage to the balancer unit gear and verify that the shaft turns smoothly. If there is any damage or malfunction, replace the balancer unit.
Install the adjustment shims in their original positions on the seat faces of the balancer unit.
With the balancer unit shaft marks in the TDC position, slowly install the balancer unit to the cylinder block to avoid interference between the crankshaft drive gear and the balancer unit driven gear.
NOTICE: Install the camshafts with the alignment slots in the camshafts lined up so the Camshaft Alignment Plate can be installed without rotating the camshafts. Make sure the lobes on the No. 1 cylinder are in the same position as noted in the disassembly procedure. Rotating the camshafts when the timing chain is removed, or installing the camshafts 180 degrees out of position, can cause severe damage to the valves and pistons.
NOTE: Install a new crankshaft sprocket diamond washer on both sides of the crankshaft sprocket.
Install the crankshaft sprocket, new crankshaft sprocket diamond washers, oil pump chain and oil pump sprocket.
The crankshaft sprocket flange must be facing away from the engine block.
Install the oil pump chain, sprocket and bolt.
NOTICE: The Camshaft Alignment Plate is for camshaft alignment only. Using this tool to prevent engine rotation can result in engine damage.
Install the Camshaft Alignment Plate in the slots on the rear of both camshafts.
Install the camshaft sprockets and the bolts. Do not tighten the bolts at this time.
Install the timing chain.
Sep 15, 2018 at 3:50 AM
CKALLEN
  • 6 POSTS
Yeah, so pretty much the engine is toast.
Sep 15, 2018 at 3:54 AM
It may be. You will need to drop the pan and check for any engine damage.
Sep 15, 2018 at 3:55 AM
CKALLEN
  • 6 POSTS
Yeah, I figured just did not want to accept it. Thanks for the help.
Sep 15, 2018 at 3:57 AM
You are welcome, glad to help.
Sep 15, 2018 at 3:59 AM
