Crank, no start
150,000 MILES • 2.5L • 4 CYL • 2WD • MANUAL
DCACE
Okay, I have my truck it has got new plugs, wires and coil pack, it’s got a new fuel filter and the thermostat, temperature sensors, cat delete get to g fuel and spark. I got it to run twice today timings good CPS wasn’t dirty. i'm running out of ideas. the inertia switch when I tapped on it freaked out but it’s not tripped. any ideas? 99 2.5 dual spark Lima manual transmission. Any ideas?
Mar 7, 2021 at 11:09 AM
  • 110,248 POSTS
You indicated it has good spark and fuel. Are you sure the fuel pressure is within spec? If you have both and it won't start, either there is a timing issue or low compression issues.
Do me a favor. See if it starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is fuel-related.
Here are a couple of links you may find helpful:
Take care and God Bless,
JOe
Mar 8, 2021 at 5:13 AM
