No crank no start issue
156,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
KE N ERGY
Started my car today it crank over but was sticking until it started then it cut off. no start no crank. all lights inside being dash broad and stereo locks all work.. disconnected the battery for hours still no start.
Jul 19, 2020 at 5:10 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
Have you tested the battery to make sure it has a good charge? Sometimes the battery will have enough of a charge to activate door locks etc., but it won't be enough to start the car. Here is a link to our tutorial on load testing your battery:
Another thing we want to be sure of is that the terminals are good and clean, here is a link to our tutorial on cleaning your battery terminals:
If you can go through these steps and get back to us with the results we will be happy to guide you through the next step(s).
We look forward to hearing back from you and thank you for using 2CarPros!
Jul 19, 2020 at 9:07 PM
