When cranking to start fuse 27 blows
2003 GMC SAVANA
297,000 MILES
JBGOOD
When the key goes into start position starter turns for one second then stops due to #27 crank fuse blown . Replaced starter and also park neutral switch.
Apr 5, 2020 at 10:18 AM
  • 110,244 POSTS
There is a smaller wire to the starter (s terminal) that only receives power when the key is in the start position. I think the wire on this vehicle is purple. Most likely there is a short to ground between the relay and starter via that wire. Check to see if there is anything on that wire that appears it could be shorting.
Here are a few links that you may find helpful:
Let me know if you notice anything.
Apr 5, 2020 at 10:29 AM
