Cranks but will not start
150,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
NAHIDH JAFFAR
Hi, the shifter light went off beside releasing alarm of the door. all fuses Checked. help please. when connect the obd I receive no connection or respond although there is 12volt in it.
Jul 9, 2020 at 8:03 AM
SQM
  • 6,383 POSTS
Generally speaking, an engine will need spark, fuel and compression to start.
You will need to check if you are getting spark to the plugs.
Here is a helpful guide:
When you turn on the key can you hear the fuel pump?
In operative fuel pump can be due to a faulty relay, wiring issue or a bad pump.
This vehicle has two fuel pump relays. They are located in the fuse box under the driver side dash (see diagram below).
Check for any corrosion or burnt pin(s).
The relay can also be tested.
Please let me know what you find or if you have any questions.
Jan 14, 2022 at 5:14 AM
