Crank but will not start
210,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
GABRIEL OZ
Hey! I was just casually driving home when I noticed all of my dash board lights were lit up. I thought I stalled for some reason so I "turned" the ignition off and tried to start it again but it didn't. It cranks but wont start now. I have already checked my fuses and replaced the camshaft position sensor also, but still no start. If you know any possibilities please let me know! Thank you!
May 17, 2019 at 10:45 AM
  • 110,251 POSTS
Welcome to 2CarPros.
Does the engine sound normal when the starter is engaged and you are trying to start it, or does it seem to be turning faster or have a different sound? If either of these are happening, record it being cranked and upload it so I can hear it. Check out the diagrams (Below).
Here is a link that discusses the most common causes for a crank no start condition. See if it is helpful to you:
Now, if cranking seems normal, you first need to check for spark and fuel to the engine. The easiest thing to do is see if it starts with starting fluid for a couple seconds. If it does, then the problem is fuel related. If it doesn't, then we have an ignition spark issue.
Here are a couple links you can follow if you don't want to try the starting fluid. They explain in general how to check fuel pressure and for ignition spark.
Here are the directions specific to you vehicle for testing fuel pressure. The attached pics correlate with the directions and include diagnostic charts. Note, you will need a scanner to complete these directions.
FUEL PRESSURE TEST
Required Special Tools:
- MB991502: Scan Tool (MUT-II)
- MB991637: Fuel Pressure Gauge Set
- MD998709: Adaptor Hose
- MD998742: Hose Adaptor
1. Release residual pressure from the fuel line to prevent fuel spray.
WARNING: To prevent a fire, cover the hose connection with shop towels to prevent splashing of fuel that could be caused by some residual pressure in the fuel pipe line.
2. Disconnect the high-pressure fuel hose at the fuel rail side.
3. Assemble the fuel pressure measurement tools as follows.
1. Remove the union joint and bolt from special tool MD998709 (adaptor hose) and instead attach special tool MD998742 (hose adaptor) to the adaptor hose.
2. Place a suitable O-ring or gasket on assembled special tools MD998709 and MD998742 and install the fuel pressure gauge.
3. Install the assembled fuel pressure measurement tools between the fuel rail and high-pressure fuel hose.
2. Install special tool MB991637 (fuel pressure gauge set) to assembled special tools MD998709 and MD998742 via a gasket.
3. Install the assembled fuel pressure measurement tools between the fuel rail and the high-pressure fuel hose.
CAUTION: To prevent damage to scan tool MB991502, always turn the ignition switch to the "LOCK" (OFF) position before connecting or disconnecting scan tool MB991502.
4. Connect scan tool MB991502 to the data link connector.
5. Use the Actuator test 07 to drive the fuel pump. Check that there is no fuel leaking from any section when the fuel pump is operating.
6. Stop the fuel pump.
7. Start the engine and run at idle.
8. Measure fuel pressure while the engine is running at idle.
Standard value: Approximately 270 kPa (38 psi) at curb idle
9. Disconnect the vacuum hose from the fuel pressure regulator and measure fuel pressure with the hose end closed with your finger.
Standard value: 330 - 350 kPa (47 - 50 psi) at curb idle
10. Check to see that fuel pressure at idle does not drop even after the engine has been revved several times.
11. Revving the engine repeatedly, hold the fuel return hose lightly with your fingers to feel that fuel pressure is present in the return hose.
NOTE: If the fuel flow rate is low, there will be no fuel pressure in the return hose.
12. If any of fuel pressure measured in steps 10 to 13 is out of specification, troubleshoot and repair according to the table.
13. Stop the engine and observe fuel pressure gauge reading. It is normal if the reading does not drop within two minutes. If it does, observe the rate of drop and troubleshoot and repair according to the table. Start, then stop the engine.
1. Squeeze the fuel return line closed to confirm leak-down occurs from defective fuel pressure regulator.
2. Squeeze the fuel supply line closed to confirm leak-down occurs from defective fuel pump check valve.
3. If pressure continues to drop with both fuel lines squeezed closed, injector(s) are leaking.
14. Release residual pressure from the fuel pipe line.
WARNING: Cover the hose connection with shop towels to prevent splash of fuel that could be caused by some residual pressure in the fuel pipe line.
15. Remove the fuel pressure gauge or special tool MB991637, and special tools MD998709 and MD998742 from the fuel rail.
16. Replace the O-ring at the end of the high-pressure fuel hose with a new one.
17. Fit the high-pressure fuel hose into the fuel rail and tighten the bolts to specified torque.
Tightening torque: 4.9 ± 1.0 (44 ± 8 in-lb)
18. Check for fuel leaks.
1. Use scan tool MB991502 to operate the fuel pump.
2. Check the fuel line for leaks, and repair as needed.
19. Disconnect scan tool MB991502.
Apr 20, 2021 at 4:47 AM
