Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Alero
Engine
Symptoms
Not Running
Cranks but will not start
2004 OLDSMOBILE ALERO
190,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
ERICSNYDER011
MEMBER
I have crank but i have no spark. changed ECM, coil packs, etc.
Mar 23, 2020 at 10:57 PM
Experienced Mechanic
Good morning,
You need fuel, spark and compression for it to run.
Did you check the fuel pressure? Can you hear the fuel pump run?
Did you check for spark? Check at the spark plug while cranking.
Did you check for compression?
Did you have your replacement ECM programmed to your VIN number?
Mar 23, 2020 at 11:06 PM
ERICSNYDER011
MEMBER
I have done all but program the ECM to my VIN wasn't sure you had to.
Mar 25, 2020 at 2:32 PM
Yes, you must for it to operate correctly.
What were the results of all the tests I suggested?
Mar 25, 2020 at 9:49 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
