Cranks but will not start
190,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
ERICSNYDER011
I have crank but i have no spark. changed ECM, coil packs, etc.
Mar 23, 2020 at 10:57 PM
Good morning,
You need fuel, spark and compression for it to run.
Did you check the fuel pressure? Can you hear the fuel pump run?
Did you check for spark? Check at the spark plug while cranking.
Did you check for compression?
Did you have your replacement ECM programmed to your VIN number?
Mar 23, 2020 at 11:06 PM
ERICSNYDER011
I have done all but program the ECM to my VIN wasn't sure you had to.
Mar 25, 2020 at 2:32 PM
Yes, you must for it to operate correctly.
What were the results of all the tests I suggested?
Mar 25, 2020 at 9:49 PM
