Crank but will not fire
179,000 MILES • 3.5L • V6 • AUTOMATIC
ANTHONY THOMAS2
My wife was driving, and the car made a noise and it started dinging and now it cranks but won't fire. I've replaced both cam and crank sensors now the battery drain every night. what would make this happen?
Mar 10, 2022 at 10:14 AM
  • 110,248 POSTS
What is the best way to describe the noise she heard? Also, if it won't start, try this. See if it starts for a couple of seconds using starting fluid. If it does and then stalls, it's a fuel-related issue. If there is no change, then it's likely an ignition issue. If that is the case, check for spark to the plugs.
Here is a link to check for spark:
If it is possible, record it cranking and upload it for me to hear. Hopefully, that will tell me where the issue is coming from.
Mar 10, 2022 at 11:43 AM
