Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Suzuki
Vitara
Engine
Symptoms
Not Running
Crank but no start
2002 SUZUKI VITARA
160,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ROBERTOTRD0993
MEMBER
1 POST
The vehicle cranks, but no have spark in any cylinders.
Nov 13, 2017 at 10:46 PM
Experienced Mechanic
Suspect the crankshaft sensor. If you have a scanner that reads live data, check to see if there is a signal from the crank sensor.
Nov 14, 2017 at 11:40 AM
STEVE W.
If the car has a tachometer you can see if it moves while cranking. Most use the crank signal to operate the tachometer.
Nov 15, 2017 at 11:23 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
