Crank but no start
160,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
ROBERTOTRD0993
The vehicle cranks, but no have spark in any cylinders.
Nov 13, 2017 at 10:46 PM
  • 110,248 POSTS
Suspect the crankshaft sensor. If you have a scanner that reads live data, check to see if there is a signal from the crank sensor.
Nov 14, 2017 at 11:40 AM
STEVE W.
  • 15,418 POSTS
If the car has a tachometer you can see if it moves while cranking. Most use the crank signal to operate the tachometer.
Nov 15, 2017 at 11:23 AM
