Crank but no start after front crankshaft seal replacement
2009 FORD FUSION
140,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
ABEL BUENO
Replaced front crankshaft seal, put everything back together but car won’t start. It cracks but no start. Do I need to readjust the timing?
Apr 3, 2020 at 12:45 PM
Good afternoon,
Did you follow these instructions?
Removal
NOTICE: Do not loosen or remove the crankshaft pulley bolt without first installing the special tools as instructed in this procedure. The crankshaft pulley and the crankshaft timing sprocket are not keyed to the crankshaft. The crankshaft, the crankshaft sprocket and the pulley are fitted together by friction, using diamond washers between the flange faces on each part. For that reason, the crankshaft sprocket is also unfastened if the pulley bolt is loosened. Before any repair requiring loosening or removal of the crankshaft pulley bolt, the crankshaft and camshafts must be locked in place by the special service tools, otherwise severe engine damage can occur.
NOTICE: During engine repair procedures, cleanliness is extremely important. Any foreign material, including any material created while cleaning gasket surfaces, that enters the oil passages, coolant passages or the oil pan can cause engine failure.
This is the procedure for removing the balancer. Did you follow this as well?
Removal
Apr 3, 2020 at 2:19 PM
