crank but no start
156,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
BRIAN MOFFETT
  • 12 POSTS
so my symptoms are the dash lights come on but my gauges do not move at all when the key is in the run position. my scanner will not connect to the obd2 connector, the mileage starts flashing. also, i have three relays that click really load when the key is in the run position they are the ASD, fuel, and the transmission relays. i have replaced the cap and rotor, the ignition coil, and the crank sensor and still the truck will not start. one day the truck ran fine and then two days later the truck would not start. the only other thing i can think of that could be wrong is the computer.
Jul 19, 2017 at 1:14 PM
  • 55,808 POSTS
Hi Brian,
It sounds like you have a voltage or battery cable issue. Can you follow this guide to load test the battery.
If it checks out look at the battery to frame grounds to make sure they are in tact.
Lets run the codes to see what come up as well.
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
Jul 20, 2017 at 4:26 AM
BRIAN MOFFETT
  • 12 POSTS
Ok I will do the load test. Also the code reader that I have worked on my other vehicles so the code reader works it just won't connect to my truck for some reason
Jul 21, 2017 at 1:50 AM
  • 55,808 POSTS
The most common reason for the code reader not to connect is a blown ECM fuse. Can you please check all fuses to take that out of the equation?
Please let us know what you find.
Cheers, Ken
Jul 21, 2017 at 3:24 AM
BRIAN MOFFETT
  • 12 POSTS
Yes I will look
Jul 21, 2017 at 4:34 AM
BRIAN MOFFETT
  • 12 POSTS
All my fuses are good. The battery load test passed. I'm going to double check all my ground wires to make sure there good
Jul 21, 2017 at 4:48 AM
BRIAN MOFFETT
  • 12 POSTS
I cleaned and reconnected all my ground wires that I could see and It still wont start. Also I did a test on my coil pack and the spark I'm getting is red instead of the bluish color that's was before and after I replaced the coil pack
Jul 21, 2017 at 6:29 AM
  • 55,808 POSTS
How long of spark is it? Can you take a picture?
Jul 21, 2017 at 7:42 AM
BRIAN MOFFETT
  • 12 POSTS
i will do that in about a half hour and try and put some pictures up.
Jul 21, 2017 at 7:53 AM
BRIAN MOFFETT
  • 12 POSTS
I couldn't get a picture but the spark would travel about a quarter of an inch but it didn't always spark either
Jul 21, 2017 at 9:52 AM
BRIAN MOFFETT
  • 12 POSTS
I also checked to see if I had power to the obd2 connector and I do
Jul 21, 2017 at 11:32 AM
  • 55,808 POSTS
It sounds like you have a computer that has gone bad. I would try to get a used one from a wrecking yard,
Cheers, Ken
Jul 22, 2017 at 5:08 AM
BRIAN MOFFETT
  • 12 POSTS
That's what I was afraid of. Thank you i will let you know
Jul 22, 2017 at 7:29 AM
  • 55,808 POSTS
Please let us know what happens, we are interested to see.
Cheers, Ken
Jul 24, 2017 at 5:00 AM
BRIAN MOFFETT
  • 12 POSTS
sorry i had to order a new computer because the wrecking yard around here dont have my pcm in stock. so i get my new part on Wednesday
Jul 24, 2017 at 5:39 AM
BRIAN MOFFETT
  • 12 POSTS
Sorry there is some hold up with the part and I still haven't received it
Aug 2, 2017 at 2:10 PM
  • 55,808 POSTS
No problem let us know when you get it :)
Aug 3, 2017 at 3:19 AM
BRIAN MOFFETT
  • 12 POSTS
I finally received my new pcm for the truck and it fixed all my issues i was having. thank you for your help.
Aug 29, 2017 at 2:37 PM
  • 55,808 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers, Ken
Aug 30, 2017 at 3:44 AM
