so my symptoms are the dash lights come on but my gauges do not move at all when the key is in the run position. my scanner will not connect to the obd2 connector, the mileage starts flashing. also, i have three relays that click really load when the key is in the run position they are the ASD, fuel, and the transmission relays. i have replaced the cap and rotor, the ignition coil, and the crank sensor and still the truck will not start. one day the truck ran fine and then two days later the truck would not start. the only other thing i can think of that could be wrong is the computer.
Jul 19, 2017 at 1:14 PM
