crank but no start
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
STEPHEN KARANJA
  • 47 POSTS
i have been able to rule out fuel pump plenty of gas coming through the fuel line when i try to start it.i have also been able to rule out my PGM relay because i replaced with another relay from another Acura that was running just fine.the only thing left is spark.i cannot see spark after a few tests.what could cause this?
I don't know what else i'm missing to test.
could camshaft sensor cause this?
please help.
Jul 18, 2021 at 11:56 AM
SQM
  • 6,383 POSTS
Have you got a chance to check the pressure of the fuel at the rail?
The ideal pressure should be 43.4-50.5 PSI with regulator vacuum hose disconnected.
Is your service engine light on? If so what is the code(s)?
You also could have a faulty crank position sensor. Or even a ignition control module.
Let me know of any questions.
Jul 18, 2021 at 1:08 PM
STEPHEN KARANJA
  • 47 POSTS
thanks for your help.i got a fuel gauge to measure fuel pressure.i cannot retrieve computer codes because the car has not been running for awhile.but will try your recommended tips.
Jul 21, 2021 at 12:58 PM
SQM
  • 6,383 POSTS
You're welcome!
Please let me know the outcome and if you need any other information.
Jul 21, 2021 at 1:40 PM
