crank but no start
235,000 MILES • 3.3L • 6 CYL
JOMILLS
  • 5 POSTS
hello,
i have the van listed above, it was misfiring and giving codes of p0300, p0203 and p0303. if remember correctly it had something to do with the fuel injector wiring. i changed out the wiring harness for the fuel injectors and now it won't fire. i tested the spark plug for spark and it is there. The plugs were wet so it seems to have fuel. it was running before the harness swap, but poorly and now it won't fire. it has a new, strong battery, i replaced the cam position sensor and the coil pack and the relays seem to be okay. what do you think?
Jan 12, 2021 at 2:40 AM
  • 55,770 POSTS
If you have a shorted injector it can cause the PCM to go full on causing the engine to flood. How wet are the plugs? Also does the system have spark? This guide can help us see what's going on:
and
Let us know what happens and please upload pictures or videos of the problem.
Jan 13, 2021 at 2:07 AM
JOMILLS
  • 5 POSTS
thanks Ken.
the plugs were pretty wet. the plugs have spark. if the PCM was stuck full on, how would i know?
Jan 13, 2021 at 6:54 AM
  • 55,770 POSTS
The plugs will be dripping wet. Lets remove the injectors and use this guide to test them:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jan 14, 2021 at 12:38 AM
JOMILLS
  • 5 POSTS
Thank you sir.
I’ll work on that trouble shooting this weekend when i have time.
Jan 14, 2021 at 1:30 AM
  • 55,770 POSTS
Jan 15, 2021 at 1:28 AM
JOMILLS
  • 5 POSTS
hello Ken,
i checked voltage coming to the fuel injector plug and it never got above 5 volts.
Jan 21, 2021 at 5:30 AM
  • 55,770 POSTS
hmm, it should be 12 volts. it sounds like the PCM has gone out. To be sure lets do a CAN scan which is the future of automotive repair. you can get a CAN scanner from Amazon for about $50.00. here is a video to show you how:
https://youtu.be/InIlnsjOVFA
Here is the location of the PCM and replacement instructions I would check the electrical connector for corrosion. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 22, 2021 at 2:33 AM
JOMILLS
  • 5 POSTS
hello Ken,
can you recommend a can scanner that can do this? i am not certain of what i need.
thank you.
Feb 5, 2021 at 1:11 AM
  • 55,770 POSTS
